| Field Doc has nothing to do with Harvest. Harvest Doc can be run on a side mount moisture sensor, just need to load 7.00D software to the moisture sensor. If you do not have a keycard with Harvest Doc on it, then you will be running yield mapping. All in tank moisture sensors mapping with brown boxes require Harvest Doc keycards, basically 60 series combines. Your dealer should be able to help you with this issue. | |
