Posted 9/26/2012 12:43 (#2609883 - in reply to #2609868) Subject: Re: RS232 from 750 to intelliview 3?
roaming
ah, sorry. I don't think the T8s have the 10-pin connector. You'll have to run wires directly into pins 9(IntelliView Tx), 10(IntelliView Rx), and 14 (splice RS232 ground) on the back of the IntelliView III. If the tractor is guidance ready, you may be able to use the existing GPS connection, if it has RS232 wires (I think it does).
