Near Intersection of I-35 & I-90 Southern Mn. | Yes, if you use the NH3 meter cal stamped on the flowmeter, then the rate applied will be the Pounds of Actual "N". This is the most common way of handling the situation.
In other words, if you are shooting for 200 pounds of acutal "N"/acre, then you would enter 200 as the target rate.
Remember when comparing the Raven total Volume (total pounds actual) against the scale ticket, you will need to multiply the total weight on the scale ticket by .82 to compare. Since NH3 is difficult to measure there will be some discrepancy from tank to tank.
Edited by tedbear 9/26/2012 07:21
