| Ed Boysun - But what if the edge of the field bellies out?
Set your A point at the first end. Drive the edge. Set your B point at the far end.
Now, if you were to drive it back, you would leave a gap in the belly.
So, estimate that it was a 4 foot belly? Turn around and start with a 4 foot offset. 'Center' the line, and auto track your way back. If the belly was a bit bigger, then you will need to follow the belly again. Make note of how much you are off the course while you are following the belly, When you turn at the next end offset that amount and re-center again.
