Posted 9/25/2012 21:51 (#2609021 - in reply to #2608910) Subject: Re: pro 600 line disconnect error
roaming
Could be a bad crimp/solder on one of the steering sensor connector terminals. Or a loose connection inside the cylinder where you can't get to it. Or anywhere in the wiring harness between the sensor and the NavII CCM3.
