| Sounds like your T2 in the controller had a bad moment. If it happens again hit your status button to see what your roll angle and rates are doing. I would put strong odds on you have some issues there, and if you unplug your EZ-Steer controller, let it sit for 30 seconds, and plug it back in again it will start behaving properly. If it happens often you may want to send the controller in for repairs.
Also, if you are nudging a lot you may consider upgrading your signal's accuracy. | |
