South Africa | I need to get gps signal from a JD ITC Receiver to a Versa display. I have a cable with partnumber PF80754 from JD to get the gps from the receiver. It connects on one side to the receiver and on the orher side is a 9pin female RS232 plug. The plug for the GPS on the Ag Leader display cable is also a 9pin female. I used a null modem cable to connect the two.
On the JD display the nmea messages is on and baud rate is 38400 with gps rate 5 hz. I am not able to get any GPS on the Versa, any suggestions? | |
