| IIC, the 2355 is designed for the 88 series tractors. That said, with a little ingenuity they can be mounted on pretty much any tractor. I bought an 806 a couple years ago that has a 2355 loader on it. The subframe sticks out quite a ways from the front of the tractor. Plus, whoever put the loader on the tractor had the rear mounting brackets for the subframe welded to the tractor's frame rails :~(
I believe the 2355 has more lifting capacity & a higher lift than the 2350. It's a well built loader. I bought the outfit for the tractor to fill in our 06 series collection so don't use the loader that much, plus we have a CAT backhoe for heavy lifting, but there's times it's handy to have a second loader around the farm . | |
