East Central Ia | I think you can get around 25-28gpm out of a single remote. We had to research this to see how many vac fans we could plumb together on our planter this spring.
As far as pressure, you will want to be under 3000psi. It seems the case tractors around here are set randomly from the factory. A lot of nieghbors have had trouble blowing hoses and when they check the pressure its way to high.
Just had a neighbor blow the end of a huge scraper cylinder out because his tractor's pressure was set to high. I would make sure you are in the 2500-2700 psi range. You could probably go closer to 2000psi without noticing any difference in performance. | |
