Posted 6/11/2012 05:48 (#2424403 - in reply to #2424384) Subject: Re: A/C leak on JD 4050?
St.Clair Co. IL.
you will find the one that is rotted will be wrapped in a black insulating cover, you may concider leaving it off when you put the new one back in, it's a pain to try to put it back on, also you may want to cut the bad one to pull it out easier. did one on a 4960, not a bad job just take your time and ask questions if you need to. Bob
