Elkmont, AL | I went through the same thing on wiring a direct command setup on a jd 4700. I have 5 sections on my boom plus the two fencerow nozzles, and it seemed like the fence row nozzles always messed up my switch assignments. I wanted the fence row nozzles on switch 1 and 7 but, finally gave up and wired the fence row nozzles back up the standard factory way and wired my other switches through direct comm. and presto everything works like it should. No big deal, my fence row nozzles just don't show coverage on the mapping screen now, but essentially the switch functions all stay the same, since the deere kit utilizes the factory switches instead of an external switch box. If you figure it out after talking to agleader please post your solution, it might apply to me also. Thanks | |
