Posted 3/15/2012 15:07 (#2288745 - in reply to #2288020) Subject: Re: Direct command in a case 4410, no boom valve control
wisconsin
If you have aim command on the sprayer the accuboom would have interfaced in the fuse box to the aim command harness. there is a connector in there that should be tagged as "boom sense" it is a rectangular 12 pin that has solid color wires in it (orange blue yellow ect) this should be connected together and if you have aim command the aim command harness tee should also be connected in there.
