Minnesota | As long as you do the 1.17 monitor version first shouldn't be a problem. You will be able to install version 1.9, don't need to worry about any versions in between what is on your display and 1.9. I have had good luck with most USB drives, if you insert it in the display, power it up, and the display doesn't acknowledge there is a USB drive connected (USB icon in the upper right corner is green), or an info window saying that new firmware as been found, chances are the USB drive isn't going to work. Doesn't matter if you get the firmware that is Trimble or Case branded, its all the same. The branding is in the base display firmware from the factory. | |
