Posted 3/12/2012 08:11 (#2282764 - in reply to #2282523) Subject: Re: Pro 600 & outer boundary
roaming
if you're recording and spraying at the same time, you'll have to turn off Boundary Control ONLY while you're recording the boundary. Then turn it back on for spraying the rest of the field interior. You can do this via a Run Screen window, so you don't have to go into the Toolbox to do it.
