| When the 252/262/372 Receivers are connected to CNH AFS/Intellisteer systems, Ports A & B are automaticly reconfigured to Defaults every time the power is cycled. This is supposed to be what happens, but I have also seen it do it after 5-10seconds like you mentioned. Probably because the Pro600 would loose its connection with the 262 as soon as you change this setting - the Pro600 would know something has changed straight away, which may cause it to do this sooner. Use Port C, as it is not reconfigured automaticly. The pins for this are found in the phisical port B. Pin 8 is IN, 6 is OUT and 5 is Gnd (see page 29 of 262 user manual) | |
