NEMO | Sounds like your dealer needs to file a D-Tac case if they haven't already. Could be that the stop blocks aren't welded on correctly. D-tac can go to engineering to get measurements for stop placement to verify this if needed. What tractor is this loader on? Are the ram guides being pushed out of the barrels? Have them look into solution # 32716 if no other problems are found. Good luck. | |
