| We have a 7240 and 1760 12 row that has 2 vac motors, one for the planter, and one for the seed cart. I only had one case drain for both vac motors. I ended up taking the end off of the return line, and sticking it down the hydraulic fill tube on the back of the tractor sealed with duck tape. Sounds hoakey, but it is a zero backpressure return, that didn't require a hole being drilled into the back of the tractor. The only thing that sucks is if it needs hyd fluid, you have to take the tape off. I don't know why you couldn't take the ends off of two hoses and figure out a way to run both into the fill hole, unless it won't take that much fluid. I was told not to tee both return lines to the one case drain I had because it could cause backpressure on the motors.
Edited by rdpwr 3/9/2012 08:37
