Near Intersection of I-35 & I-90 Southern Mn. | The pinout for the second camera is the same as the first but goes into Port B. I have used a Cab Cam camera to Port A and an Ag Cam camera to Port B at the same time. The menu allows you to toggle between A, B and the usual screen.
For the Cab Cam type camera there are four wires. One is for sound so that is not used. The power, ground and signal are as indicated in the first reply.
Edited by tedbear 3/3/2012 11:45
