Minnesota | First thing I will say is that the EZ Guide 250 display is not compatible with either the EZ-Boom or Field IQ system(replaced EZ-Boom), you will need an EZ500, FM750 or FM1000 display to run sprayer rate and section controls (also CNH displays will also be able to run Field IQ for sprayers later this year), most of the time you can completely eliminate the OEM spray controller if the system is compatible. Depending on what microTrak controller you have though, it can be done. I have replaced a MT3405 with an EZ-Boom system and worked flawlessly. | |
