| You will need a Greenstar harness and implement adaptor harness to connect the Planter, 2600, receiver, and ATU. The tractor will only provide power to the harness.
The easiest way to map with a planter is hook up an implement height switch on the planter parallel arm to the implement adaptor harness. You will need switch AT157457, and bracket A71505 plus wiring to connect.
PF80845 will plug into the greenstar/implement harness and provide power and signal to ATU, you should have one of these from your ATU.
PF90411 and PF80869 will be needed to attach the ATU to the case steering column and steering shaft.
Also, a PF90453 is an Autotrac resume switch that can be mounted on your armrest.
Hope this helps, if you have additional questions feel free to get ahold of me, I live and work in ECIL. | |
