roaming | You will need to make sure it's got the tractor software loaded. Go to Toolbox > Display, and check the list that pops up when you press the Current Vehicle window. If you only see AFX Combine, then you need to have your dealer out to load software. If it says Large Tractor, then you can change to the tractor software. You still might want to have it updated to the latest and greatest version, but at least you can put it in your tractor for now. | |
