Posted 12/16/2011 20:31 (#2107369) Subject: FMX1000 to 9670
Darke County, Ohio
We are looking at a 9670 with the JD Moisture and yield sensors. Is there any way to hook up our FMX 1000 Monitor to be able to map our yields. Was going to use the 1000 for steering anyway. The built in unit on the combine will show the yield and moisture as we go thru the field but not map it. Is that not correct??
