| Soil samples should be taken before you start farming the ground and after you no longer farm the ground. If the fertility is higher when you quit than when you started, you should be reimbursed for the difference. If it's the other way around you should pay for the difference.
Any inputs such as herbicides and equipment costs and labor costs should be reimbursed if somehow he is able to tear the ground away from you after you've already started preparing for the next years crop.
Yes, you really should have a written agreement. | |
