Kansas | not the cheapest way, but Leica Mojo RTK Console, with the ability to emulate the StarFire signal and run RTK into the GS2 with only an SF1 unlock is the slickest way to go, but you can also use a Intuicom RTK bridge with the built in 900 MHZ radio, the only downside is that youll need everything unlocked for RTK to use the signal with the ITC or SF3000 / 900 MHZ radio combination. | |
