Nebraska | I have the same question. We are running a Krause Gladiator with an aNH3 controlled by a JD rate controller and a Montag Cart controlled by the GS3 through Field Doc Connect and a Micro-Trac 1000 controller. New system this year - and was not confident we could control it. Was told that this would work - just PLUG and PLAY. "Right" IT NEVER works that way, but it is finally comunicating and working after 4 MT controllers and a software patch from Micro-Trac. It would be simpler to simply run the JD Rate controllers IF THEY HAVE THE BUGS WORKED OUT. | |
