Humeston, IA | If one has two or more implements with ECUs (say, a planter and a fertilizer applicator) that are ISOBus compatible and connected to the Canbus, how does the operator switch between tasks on the virtual terminal? Do both working sets from both ECU's get loaded in the VT at the same time, or does one get loaded, then dumped and the other loaded when the 2nd is selected? I'd assume the one not presently in view would still function as previously set, right?
Thanks! |
