| The key is the type of case you put it in. I use a Otterbox defender, and have had good luck. Multiple drops on concrete, extreme dusty conditions. It is not waterproof. The only drawback is that it is a little bulky, as is most highly protective cases. It also is hard to slide in and out of a pocket, because the soft case does not slide well, but this also helps it stay put when in the cab.
I just ordered a waterproof case from LifeProof, which is much slimmer, and highly rated. We will see how to goes. | |
