| Have a 600 Quad-trac w/Pro 700. JD electronics/Anhydrous bar with two JD rate controllers. Put JD ISO harness in the quad, outputting NMEA from the NAV II to the 2600. The 2600 has fixed DGPS. I couldn't get ground speed with just outputting NMEA to the 2600. So installed radar cable from the Quad to the JD ISO/Universal harness. Finally got ground speed to the 2600, but it was about a 1.5 mph slower than the A-post on quad and the 700 display. Manually calibrated the radar in the Quad to match the 2600, so all speeds were matching. That doesn't work, because now the Quad is about 4 to 5 mph slower (tops out at 18 mph, when we r really going 24) now we are considerably light on anhydrous. Need some advice. Has anybody done this? I have had success with this during planting, but didn't have the 2 JD rate controllers. Thanks | |
