WNW Illinois, Henry Co | My 8010 came on with the wire disconnected, found the gear on the concave motor was missing, letting the concave move on its own, put a wrench on the nut on adjuster once in correct setting, wired it into place until new gear for motor gets here. can you believe that gear is GLUED onto the shaft not pinned. needs 24 hours to set, so guess the wrench will be there till it rains. lol.
personally don't think the glue withstands the constant vibration on the concave. will look at pinning in place also, but not there yet to see.
safe harvest | |
