| What sytem are you getting your elevations maps from? What software are you using to design you levees? What gps system are you planning on steering the levee design with? I have been trying to get Outback Guidance to add this type of feature to the S3. All of the data is in there if you are recording your field and using RTK. The system is recording elevation (survey). So I would like to be able to take my job file from the Outback and get it into some software and design my levee contours and then create some sort of template that I can get back into my S3 and have it drive the levees. | |
