roaming | when one of the elevator paddles is at TDC, you need to have 3/8" to 1/2" clearance between the tip of that paddle and the deflector plate in the top of the elevator. Once you have that clearance, make any other adjustments to the elevator at the bottom sprocket.
There are yield monitor tutorials here: http://caseihafs.com/tutorials.php
The wizard makes it even easier than what the tutorial shows. | |
