WCIL | In Apex setup a Task for Soybean harvest and select a head to use for implement #1 and specify the Machine as well. If the task stays the same then it should automatically select the head you want every time. I've got one card setup for corn and one card setup for beans with tasks on each that specify the heads. I think the only time I've had to select heads is when I've cleared out my cards completely and reloaded setup data and started up the display for the first time.
Last year I had these tasks setup but then Dad didn't switch tasks when he switched crops and the idea backfired. This year I've been running the combine and kept separate memory cards for each crop with only setup data for those crops on the respective cards and it's worked so far, but dad also hasn't been in the machine when switching crops. | |
