Posted 10/4/2011 20:15 (#1990751 - in reply to #1990101) Subject: Re: ez guide 250 Optional antenna
1 1/4 mile south of Tedbear
A Garmin 18x 5hz is a smart antenna (GPS is inside)
A 250 has the GPS inside of it. The antenna is just that an antenna.
If you look up the accuracy on both the 18 & the 250 you will find the 250 with the patch antenna has quite a bit better accuracy than the 18x!
