Posted 9/25/2011 22:02 (#1978961) Subject: 4710 jd with Trimble boom control prob
Madison, fl
Have a 4710 with the tremble field I q and 750 just for swath control use the jd system for flow. But lately it has gotten to where when you go in third the flow will surge and stop surge and stop and the thing that seems to trigger it is if you use the cutoff on the handle instead of cutting the master switch off on the I q. Any suggestions would be very appreciated T.I.A.
