N Central IA | I have a Green Star yield monitor and a brown box used for mapping, did some plots yesterday and printed out some maps and my math skills are being challenged. I seem to have two different yield results on the same map, here is what I have. Area .51 acres dry weight 5840.26 lbs total yield 104.29 these numbers figure out to be 204.49 bu/ace. Then I also have avg dry weight 12029.95 lb/acre avg yield 214.82 on same yield summary. Which numbers are correct and why do I have two different results on the same map summary. Two other maps were the same way and a third both numbers matched up. Which numbers do I use. | |
