| I wired a 9500 combine a few years back with a greenstar harness, yield and moisture sensors. I remember having to have the moisture sensor software updated so it would work with my 2600 display. I bought a 9650 and it has a moisture sensor also but the dealer said it would have to be updated to work with a 2600. I swapped the updated one from the 9500 onto the 9650 because it's updated and alot newer. Then I get reading about voltages and such. Is this going to work? Or should I switch them back and update the one the 9650 came with?? Anyone knowledgeable about what I'm dealing with?? Thank you | |
