WC IN | A portable base is going to run you the cost of a receiver on RTK with a radio. $9500 for one on 450 MHz and then the price of a tripod and battery setup. Probably look around $13000. To upgrade your current equipment is going to cost you RTK activation on your receiver ($3000) and the radio ($1800 for 450 MHz $1400 for 900 MHz). Your display will not need any more activations to use RTK. Via Mcline | |
