Posted 9/18/2011 15:52 (#1967769 - in reply to #1967628) Subject: RE: trimble 262 to IPAQ
the Netherlands
You will probably need a different data cable (262 connections are quite different from the 122 connections), but apart from that, it should be possible. Both the 122 and the 262 have NMEA output, which can be used by the IPAQ.
