Posted 9/19/2011 21:55 (#1969894 - in reply to #1964984) Subject: Re: Trimble light bar with nav 2?
SW Missouri
So you can set an A-B line through the 21A? or can you just engage and use the 21a as a lightbar. I may be wrong but I was under the impression that you could not use the 21a as a stand alone system. Also I don't believe the newer versions for the Nav II will work with a 132. I could be wrong though......
