Posted 9/12/2011 12:36 (#1958885 - in reply to #1956496) Subject: Re: AFS desktop software
Terril, IA
check your projection and make sure that is correct. right click on the grower in the management tree. then hit edit item and the click on the projection tab. here you can check you datum and projection and make sure those are correct.
