The other post is correct that Case vers ViperPros come with no VRA unlock. You need the Validation number from your Viper and you purchase the unlock from a Raven dealer. Raven Vipers come with single product VRA turned on. You only have to buy multiproduct VRA if you need it.
Boundries do not apply to job files. Your option would be to have accuboom spray/no spray zone files for different fields. Those you can select when starting a job. You would have to trace them with a Viper and either a sprayer or set it up on a 4 wheeler and physically trace the field. I do not know of a way to convert a boundry into a spray zone file.
The vast majority of commercial users simply start a job without a spray zone. You still get the applied map and all of the customer info that the operator puts in. If you have a weather station it will save that info to the job as well. If you have ver 3.4 Viper software and purchase the AgX unlock then you can upload prepopulated jobs from SST Sumit Pro desktop software. |
