| Check to see that the frame is not bent. If the last guy liked to road it with too much fert. in it could be boughed. Also check the outside row units to see that they are not bent as they are the ones facing the cab and sometimes get bumped in and out of fields. Had a couple of JD planters and went Kinze. Few things I miss about the JD but not enough to ever go back. Can't beat how a Kinze folds and you can adjust it or work on it standing up not on your hands and knees !! | |
