Posted 8/24/2011 22:59 (#1929165 - in reply to #1929082) Subject: Re: setting overlap with ez boom and 500
you would need to hit the u-arrow, not finished with current field,scroll down down to implement setup. to set overlap, width, offset, but I aggree with wtw because it will make the acres covered more accurate. setting some overlap when going around multiple passes on the ends is must to keep booms from comming on or you have to turn off the master during turns.
