Posted 8/24/2011 17:48 (#1928488 - in reply to #1928474) Subject: Re: CR 9060 + Intelliview III + CFX 750 Display
roaming
Yes. You will need a Trimble Autopilot kit for the combine. It will run as a standalone system, and the IntelliView III will run separately as the combine display and yield monitor. You can also export GPS from the AP system to the IntelliView III for yield mapping if you want.
