Posted 8/22/2011 08:00 (#1924092 - in reply to #1923796) Subject: Re: 2188 CIH w/Insight...elevator speed problem
In some combines, the same type of sensor is used elsewhere. If so you might try swapping the clean grain elevator speed sensor with another to see if this helps.
I remember one red combine that had the problem that you have. The combine's monitoring system didn't complain but the Ag Leader showed erratic elevator speed. A new sensor took care of the problem.
