NE South Dakota Clark, SD | If you are going to order the planter with Trucounts, The A5 screen and clutch control module shoud be part of the deal. The best part of using the complete Dickey John setup is when it turns a row off, the pop. monitor knows it should be off. If you use EZ boom to control the clutches, you will get not planting warnings on the Intelliag monitor. The 500 will export NMEA to the Intelliag just fine. Make sure you set it to 5 Hz. I would recommend Omni signal or better. If you have any questions, my contact info is in my profile |
