Posted 8/20/2011 18:54 (#1921699 - in reply to #1919996) Subject: Re: trimble 542 base issue
Brisbane, Australia
When you say, "Signal to the 262 rovers seem fine", does the 262 have a constant bright green LED on the back of it indicating an RTK fix at the same time that the display is not registering RTK? If this so, does the display actually see the 262 as being present (i.e. connected to the display)?
