NW Central Iowa (Fort Dodge) | You have two options:
Option 1 (which is what I am currently doing)
Joey 900mhz Radios - extremely cheap, I have made a cable that plugs in the Aux Port of the ParaDyme for a external radio. The aux port will power up the joey and besides power and ground all you need is tx and rx. Also need to by a external Whip to mount on the cab of the tractor.
Set up the PD as external Radio and 34800 baud and off you go, one thing you cannot do is change the channel of the radio, so after you set the radio up for the proper channel your set, if I would ever need to change channels I would have to hook up to a 252/ag remote.
Or SNB900, SiteNet900,
Option 2 - clean route
Buy from Ag Leader the Repeater Kit and the MS750 tee cable, and the Integrated radio kit, its a cleaner install
The MS750 will out put cmr or cmr+ to the repeater and then the repeater will out put INX out to the PD internal Radio. |
