East Central, Nebraska | if you have any hilly (rough) farm ground you are going to learn really quick how that all happens because when you go through a waterway picking corn and lift up the head a little too far it stops mapping and contitues to count bushels, it really messes up the map. You lift it and it stops counting acres and stops mapping and then you put the head down over the on/off point and it starts again, meanwhile the flow sensor never missed a beat. In the end you endup with a total amount of acres that is off and and a yield per acre that is off but your total lbs and bushels should be as accurate as it would be on any other field. If your elevator has rpms and your flow sensor is recieving taps then it will count.
On another note, good choice in beer. | |
