Search Forums | Classifieds (196) | Skins | Language
Batteries
Gerald J.
Posted 7/9/2011 16:05 (#1855539 - in reply to #1855442)
Subject: Re: Batteries
I"m getting better battery life with the minders. Wallyworld charges $20 for one that seems to do me just fine. Probably could be rotated amongst a collection of batteries, a few days each battery, as long as a week out of each month.
Batteries are made differently than they used to be long ago. But then poor voltage regulators tended to abuse them. 30 40 or more years ago the lead was alloyed with antimony for mechanical strength, unfortunately the antimony was discovered (first in a telephone office with a building full of batteries by stibene gas in the air) to producing local action and speeding up self discharge. Then the battery world went to calcium (its a metal in its pure form with the carbonate of limestone removed, highly reactive to water and air) which cured the local action problem but the resulting plates are weaker. And makers have refined the manufacturing process to reduce the materials in the battery. With the weaker grids, deep discharge cycles are close to fatal if done once, almost sure fatal by the 5th time. Since the active materials swell on discharge they either get dislodged from the grids or warp the grids. And that warping flexes the grids where they are grouped in a lead block and they snap off.
Then batteries are made without filling holes which can keep electrolyte in if not overcharged, but prevents adding distilled water when needed. Or knowing added water is needed.
Used to a battery store, like Sears, would keep all the batteries in the battery room with trickle chargers on them so they were fresh when sold. Now everybody lets them set on the shelf for 6 months or a year, being careful to keep the old stock out front. If you can get to the back of the battery rack and learn the maker's date coding (which is often very clear) or buy the day the rack is filled up after your particular battery has been restocked, you probably can get a battery made in the past 3 or 4 weeks and it will give you much better service. One local farm store has a sign on the rack now to take the battery to the automotive repair desk where they will do a load check and then engrave the sold date. I saw some 6 month old batteries on that rack, but I was able to pick one from the back with Jun 2011 data of manufacture. It also tested good, but I put a charger on it before starting the tractor with it.
Then there are stamped brass battery post connectors that eventually corrode and crack. Cost me a battery in my pickup last month. And it was a special from Ford with two grounded wires wandering off. I changed things around a lot with a lead battery post to side terminal adapter and with the remains of the brass clip converted to a simple lug. Long ago, battery posts were cast in place and thoroughly plugged their hole in the top of the battery. So fumes didn't leak out there, Today the plastic and the posts are molded separately and much of the battery venting is right against the connector, so the little felt washers are a benefit. It would be more benefit to use hot glue or epoxy to seal the posts to the battery case top. Then posts have always needed cleaning annually for 12 volt and every three months for 6 volt systems. The battery cleaning brushes are marginal, I learned from my dad long ago that using a sturdy knife and scraping until shiny soft lead was exposed made for better connection longevity, then covered with grease or battery post paint made the connections last better.
Gerald J.
